Example Code
Playing a Single Audio Channel from a .wav File
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example makes use of the Sound Files VIs to read a .wav sound file and selectively play only one of the channels (by default, it is set up for a 2 channel source).
Description
Essentially, this is based on the 'Sound File to Sound Output' shipping example, but with the functionality to select either the Left or Right channel to be played at a time.  This may be useful in applications where it is desired to test a multichannel speaker setup, or also as a starting point to send different sound output to each speaker.
Requirements
  • LabVIEW 2012 (or compatible)
  • Sound output device capable of playing at least 2 channels of audio
  1. Select a .wav sound file to test in the file dialog box (a sample has been included).
  2. Select a channel to mute, Left or Right.
  3. Run the VI and listen with a pair of stereo speakers or headphones to confirm that the correct channel has been removed.
VI Block Diagram
