Overview:
Coding that exemplifies how to play a WAV File in LabVIEW.
Description:
This Example Code shows how to play a .wav sound file from a storage card on your Mobile Device. All the VIs used to make this code can be found in the Mobile Module Graphics & Sound VI Palettes.
Requirements:
LabVIEW 2012 or compatible
Steps to Implement or Execute Code:
1. Select the desired WAV file.
2. Run the VI.
3. Use the Play Sound Button to hear the sound.
4. Stop the execution with the Exit Button.
Additional Information or References:
