Example Code
Play Audio from Data File in LabVIEW
Code and Documents
Overview:
This VI exemplifies how to read the values of an ASCII file and play it as audio.
Description:
This example is useful to reproduce audios that were previously recorded in ASCII files. We use the Read From Spreadsheet File VI to obtain the data and pass it to the sound VIs.
Requirements:
LabVIEW 2012 or compatible
Steps to Implement or Execute Code:
1. Configure the Sound Format
2. Run the VI
3. Select the .dat ASCII file desired
Additional Information or References:
Snippet 7801.png**This document has been updated to meet the current required format for the NI Code Exchange.**
Andy Chang
