This VI allows you to perform frequency analysis on a block of plain text.
Description
This will give you the letter distributions of a certain block of text that you input into the string control. This allows you to perform analysis on encrypted messages to see if there are any data leaks.
This example displays a Caesar Cipher implementation in LabVIEW: https://decibel.ni.com/content/docs/DOC-39294
Requirements
LabVIEW 2013 (or compatible).
1. Input the String.
2. Run the VI.
