Example Code
Pixmap Compass Rotation using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example VI demonstrates how to control the Pixmap.
Description
In this example vi, picture of compass is dealt with pixmap. The Unflatten Pixmap.vi converts graphic data into 2 D array. This enables LabVIEW to control the direction of graphics by calculating each components of array as complex. The calculated data is then feedbacked by shift-register and reconstructed by Flatten Pixmap.vi.
Requirements
 ・LabVIEW Base Development System 2012 (or compatible)
  1. Download the VI “Pixmap Compass Rotation 2012 NIVerified.vi”
  2. Run the program
VI Block Diagram
Comments
zhoudeng
Member
Member
on
hello boss,
thank you very much for sharing this code. but can u save this file as a labview 2010 compatible file? i am using gthe 2010 version. thank you very much. or if possible, can u please have a high definition screen shot of the block diagram ?/
thank you very much boss.
all the best to you
Joe
