Example Code
Ping IP Address using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example VI demonstrates how to access command prompt and ping IP address with LabVIEW.
Description
You can check whether specific IP address within your subnet is used or not by command prompt. This can be implemented in LabVIEW by using “System Exec.vi”. In this example VI, every time PING IP button is pressed, “Pinging IP” is executed in command prompt. This example shows how to use command prompt in LabVIEW, which can be applied in many ways such as executing other files.
Requirements
 ・LabVIEW Base Development System 2012 (or compatible)
  1. Download “Ping IP Address 2012 NIVerified.vi”
  2. Run the program.
VI Front Panel
VI Block Diagram
Ben B.
National Instruments UK & Ireland
"I've looked into the reset button, the science is impossible!"
