Example Code
Pie Chart using LabVIEW picture control
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example generates a pie chart with legend using the LabVIEW picture control.
Description
This example generates a pie chart using the LabVIEW picture control.  Given an array of clusters containing a label and a value, a pie chart with legend is generated and displayed.
Pie Chart 2012.vi is the VI that actually creates the chart.  Create Chart 2012.vi is a test VI used to show what the chart looks like.
Requirements:
  • LabVIEW 2012 (or compatible)
  1. Download the attached ZIP file and open the project file.
  2. Open Create Chart 2012.vi and specify the Labels and Values in Test Value cluster array.
  3. Run the VI and a pie chart with legend is generated and displayed.
  4. If you want to view how the pie chart is created, open the Pie Chart 2012.vi to show the details.
Front Panel of Create Chart 2012.vi
VI Snippet of Pie Chart 2012.vi
Donovan
Comments
JLMommy
Member Member
Member
on
Awesome example - especially if you can't get the ActiveX controls to properly load for the other pie chart examples!  😃
Becky Linton
LabVIEW Champion
Certified LabVIEW Architect
Senior Systems Engineer, Spherea US
GCentral
gfa
Member
Member
on
Congratulations,
a very nice example. It work fine and it is easy to merge inside other applications. Just a note: due to array that set slice colors, the maximum number of slices is limited to 10. But it is rather easy to workaround this problem...
Aht22
Member
Member
on
very nice example but i have some query i integrate it in my program but the chart legend is change our position sometime in very time or after  2 to 3  values update...
kindly help in this regards...
