Example Code
Pick case based on 3 Booleans
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview:
Detects Boolean logic easier.
Description:
This code makes usage of case structures and the select VI to convert the boolean logic to numbers and depending on the addition result, the correct behavior is displayed.
Requirements:
LabVIEW 2012 (or compatible).
Steps to Implement or Execute Code:
1. Run the VI
2. Activate and deactivate the boolean controls and check on the String indicator that the data displayed matches your selection.
Additional Information or References:
"**This document has been updated to meet the current required format for the NI Code Exchange.**".
Will
CLA, CLED, CTD, Former CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
Comments
leamon
Member
Member
on
i press boolean1,when i want to switch boolen2,i need press boolean1 again ,it is not convenient
if i press boolean1 and 2,there is no string output.
Mark_Holm
Member
Member
on
If all you want to do is check which of three butons is pushed, an event structure would be a lot cleaner.
If you put logic like this inside an event for a fourth button, you could check the positions of three booleans at once, but as shown, it can only reliably check for one at a time (assuming they are front panel buttons).
It would be more elegant and more extensible to make the values increase in binary fashion: instead of 1,10,50 make it 1,2,4...using U32 representation, you could do up to 32 booleans at once this way and any combinations that mattered too.  For instance, assuming you have a setup where you can register more than one boolean at a time, 5 would be the case where inputs 1 and 4 were both true.
