Example Code
Period Length Measurements using Zero Crossing Method
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
To take period estimates for data using a zero crossing method
Description:
This code allows the user to take period estimates for data using a zero crossing method. It measures the time gap between rising edges which cross a trigger value. It will function with any wave, but due to lack of hysteresis, noisy signals can false trigger. Signal Conditioning (software or hardware based) smoothing beforehand can minimize this issue.
Steps to implement or execute code
To implement this example:
  1. Run the VI
  2. (Optional) Turn on the Highlight Execution to see the flow of the VI
To execute this example:
  1. Install the required software.
  2. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
Hardware
Kyle M.
Applications Engineering
Comments
shb
Active Participant
Active Participant
on
The shift register of the array is not initialized! When running a 2nd time you will get the new array appended to the previous one.
And there is room for optimisation.
