Description
Description-Separate-1The program reads in data of the form potential, current, time, from a file created by a Princeton Applied Research potentiostat/galvanostat.
The program determines the peak voltage, peak current and peak area of the user selected peak.
The peak is selected by using two cursors and a switch that tells the program that the peak is above or below the baseline set by the cursors.
The program displays the data from the file and the baseline corrected peak in two separate xy graphs.
Description-Separate-2
