Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
The TestStand Application Manager supports processing custom command line arguments through the ProcessUserCommandLineArguments event. This can prove useful when automating test execution from a CI server.
This example is similar to the LabWindows/CVI Basic User Interface, but has been modified to accept the following command line arguments:
| Option | Purpose |
| /SimulateFailure <failures> | When used with the included example sequence file, this suppresses the simulation dialog and instead simulate failures as specified. This argument accepts the following parameters:
This example demonstrates the following concepts:
static void DisplayError(int errorCode)
if (errorCode < 0)
printf("Error: %d %s",errorCode,errMsg);
TSUI_ApplicationMgrSetExitCode (gMainWindow.applicationMgr, NULL, errorCode);
tsErrChk( TSUI_ApplicationMgrAddCommandLineArgumentsHelp (gMainWindow.applicationMgr, &errorInfo, "[/SimulateFailure <failures>]", "<failures>: components to fail separated by spaces.\nvalid parameters are: Keyboard, Video, Power, CPU, ROM, & RAM", ""));
HRESULT CVICALLBACK ApplicationMgr_OnUserMessage (CAObjHandle caServerObjHandle, void *caCallbackData, TSUIObj_UIMessage uiMsg)
int error = 0;
LPUNKNOWN tempPropObject = 0;
CAObjHandle SeqContext = 0;
enum TSEnum_UIMessageCodes msgEvent;
tsErrChk( TS_UIMessageGetEvent (uiMsg, &errorInfo, &msgEvent));
tsErrChk( TS_UIMessageGetActiveXData (uiMsg, &errorInfo, &tempPropObject));
CA_CreateObjHandleFromInterface (tempPropObject, &IID_IUnknown, 0, LOCALE_NEUTRAL, 0, 0, &SeqContext);
if (msgEvent == TS_UIMsg_UserMessageBase +1)
tsErrChk( TS_PropertySetValBoolean ( SeqContext, &errorInfo, "Locals.UiMsgHandled", 0, VTRUE));
tsErrChk( TS_PropertySetValNumber ( SeqContext, &errorInfo, "Locals.KeyboardValue", 0, fails.Keyboard));
tsErrChk( TS_PropertySetValNumber ( SeqContext, &errorInfo, "Locals.VideoValue", 0, fails.Video));
tsErrChk( TS_PropertySetValBoolean ( SeqContext, &errorInfo, "Locals.PowerFail", 0, fails.Power));
tsErrChk( TS_PropertySetValBoolean ( SeqContext, &errorInfo, "Locals.CPUFail", 0, fails.CPU));
tsErrChk( TS_PropertySetValBoolean ( SeqContext, &errorInfo, "Locals.ROMFail", 0, fails.ROM));
tsErrChk( TS_PropertySetValBoolean ( SeqContext, &errorInfo, "Locals.RAMFail", 0, fails.RAM));
Error:
CA_DiscardObjHandle(SeqContext);
DisplayError(error);
return error < 0 ? E_FAIL : S_OK;
Note: By default, TestStand shows dialogs under certain conditions. This can cause hangs when automating sequence execution without user input, such as when ran from a CI Server. In order to prevent popups that require user input, configure the following options:
TestStand 2014 SP1 or later
LabWindows/CVI 2015 or later
TestExec /?
TestExec /runEntryPoint "Single Pass" "<ExampleDir>\TestSequence\Computer Motherboard Test Sequence.seq" /SimulateFailure Keyboard Video RAM /quit
TestStand Help: ProcessUserCommandLineArguments Event
TestStand Help: Configuring Sequence Editor and User Interface Startup Options
