Overview
This examples shows how to call a LabVIEW-built executable from the command line, also passing user-defined arguments to the executable.
Description
It is possible to call any executable from the command line using LabVIEW System Exec.vi and pass user-defined arguments. Using Application>>Command Line Arguments Property Node you can read the value of the arguments passed to the executable when called from the command line.
Requirements
Distributing Applications with the LabVIEW Application Builder
How to Pass Command Line Arguments to a LabVIEW executable
Description-Separate-2
When creating the executable, remember to Check the Pass all command line arguments to application box in the Advanced category
This method works for me to send command to dediware command line application using SYST EXE in LabVIEW.
