Overview
This example will read a text file and return each line of the text file in an array of strings.
Description: VI read user defined text file and return requested separate lines of the file in an array of strings.
Requirements
LabVIEW 2012 (or compatible).
Steps to Implement or Execute Code:
1. Set a file path
2. Set the number of first lines to read
3. Run VI
Additional Information or References:
Notes:
This will not work with all file types, just text files (txt, bat).
