Overview
This VI will give the user ability to pan or zoom on one graph and have the same action be applied across all other graphs.
Description:
This example would show you how to manipulate a graph of one of the front panel's object that would be applied the same into any other graphs using the property node.
Steps to implement or execute code
To implement this example:
- Run the VI
- Modify the desired action to be applied on the Waveform Graph 1
- Observe that the rest of the graphs change
To execute this example:
- Install the required software.
- Connect the DAQ hardware that supports the Analog Input features
- Confirm the connection with the MAX with TestPanel
- Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Analog Input Module
