Overview
This VI will return true if the input number is palindromic.
Description
A palindromic number is a number which looks the same forward and backwards. For Example: 11, 434, 7269627. This code has three inputs, Number In, Allow Negative Numbers, and Error In. Number In is the number you wish to determine if it is palindromic or not. Allow Negative Numbers is a boolean.
-True means that negative numbers will be considered without the sign.
-False means that the vi will return false if the number is negative.
Its output is true if the number is palindromic and false if it is not.
Requirements
VI Block Diagram
