Overview
This collection of VIs demonstrates multiple ways to implement a Phase Lock Loop (PLL) in LabVIEW.
Description
The examples demonstrate three different options of PLL regulation and control.The simplest form of the PLL examples (PLL_Simple Phase Only.vi) uses the Y-values of two signals and regulates the phase of one signal as long as both are in phase. The 2nd example (PLL_Simple Phase and Frequency.vi) is implemented with waveform datatypes, where the frequency and the phase are regulated. The 3rd example (PLL_Phase and Frequency_PID.vi) uses a PI(D) controller for both frequency and phase.
Description of each VI is included on Block diagram.
For more information, visit the following site: http://en.wikipedia.org/wiki/PLL
Requirements:
LabVIEW 2012 (or compatible)
LabVIEW Control and Simulation Toolkit 2012
Steps to Implement or Execute Code:
Additional Information or References:
Snippet of PLL_Simple Phase.vi
Snippet of PLL_PID.vi
Snippet of PLL_Simple Phase and Frequency.vi
**This document has been updated to meet the current required format for the NI Code Exchange. **
PID toolkit required?
My LabVIEW searching for PID.vi and PID(DBL).vi when I try to open to PLL_PID.vi. I'm assuming this example requires the PID toolkit to run PLL_PID.VI. True?
PID Toolkit
That's true. But I am only using the P and I, so it shouldn't that hard to replace the PID.vi with your own algorithm. Another option would be to use LabVIEW Simulation.
Works great!
Thanks! Works like a charm now, especially the "cheated" equation :)
Many thanks!
I came across this example and I think its a really good one. I am trying to closely emulate a 60Hz signal (Electrical Line voltage), but as we know it is not always exactly 60Hz. I want to follow that signal and generate a sine wave of that frequency. Any suggestions?
I was planning to use the PLL_Simple_WithTime.vi for this and modify it.
Thanks in advance.
