1. Overview
This VI is an example of using the PID VI for a PWM application. For a real application all that is needed is the PID VI and the Output to PWM Logic. Together these can be put in the while loop of a real application.
2. Description
Proportional-Integral-Derivative (PID) controllers are common feedback controllers. In PID control, you specify a process variable and a setpoint. The process variable is the system parameter you want to control, such as temperature, pressure, or flow rate, and the setpoint is the desired value for that system parameter. A PID controller determines a controller output value, for example the heater power or valve position, and applies the controller output value to the system to drive the process variable toward the setpoint value.
3. Requirements
4. Steps to Implement or Execute Code
5. Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines.**
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
how i can use PID for to control Motor DC with arduino in labview
You would have to put the PID in the arduino code for anything but a very, very slow system (seconds).
i want to control Dc motor with arduino interface labview but using PID control
what mean of PID.vi output?is a number!!
