HI All
This driver is developed for phytec USB PCAN device.
Kindly Check the same.
Please give your comments
Regards
Prabhakant Patil
Please click on like if you like it. ![]()
Your valuable suggestions are always welcome for the improvement.
Prabhakant
Thank you~~~
can you add more VI's . for selecting channels ,message filitering etc
can you provide PLIN driver please? thank you in advance!
your driver is easier to use,but seems we can‘t utilize it for controlling multiple PCANs from one PC.
Hi Prabhakant,
your driver look much better the the original, but how can I set the bus speed to 83,3kBaud
Your driver could also be used with PCAN - USB FD.
Now I trying to make the driver which using PCAN-XCP API.
I am glad, if you have already build it.
Thank you much On behalf of the Chinese people, It's very easy to use.
For PCAN-USB XL this should work? Is not working for me give error CAN_ERR_QRCVEMPTY.
