Example Code
Overlap and Add in LabVIEW
Code and Documents
Overview
Overlap and add is a very common operation in digital signal processing streaming applications.  It is often the preferred method to process large amounts of data where memory and/or storage devices are constrained and where the overhead of processing samples individually significantly reduces the systems’ performance.
Description
Overlap and Add Operation
The basic principle is as follows.  Assume you have a sampled signal H that is too big to be processed all at once.  First, split H into a series of contiguous blocks containing N elements each such that
h = h1 + h2 + h3 + …
The desired result of applying a Finite Impulse Response (FIR) filter with M taps is given by the convolution operation
f * h = f * (h1 + h2 + h3 + … ) = f * h1 + f * h2 + f * h3 + …
However, the individual convolution operations result in an output filtered sequence of size N + M - 1, composed of a filtered data segment fi concatenated with a transient ti.  The correct filtered ith segment of size N is given by
f * hi = fi + ti-1
The simplest overlap and add implementation is array addition.  However, it is necessary to keep track of the filtered data (size N) and the delayed transient for that segment (size M - 1).  Figure 1 shows an implementation where the Array Shift function is used to save the transient and the feedback node is used to delay it for the next iteration.
Figure 1:  Overlap and Add Implementation
The overlap and add VI can be inserted in a loop to process the data on a frame-by-frame (block-by-block) basis.  The LabVIEW block diagram in Figure 2 shows a filtering operation done on the entire sound data.  The lower branch of the block diagram applies the filter to the entire data set all at once while the For Loop performs the same filtering operation using the overlap and add VI.
Figure 2:  Overlap and Add Program
The results of the LabVIEW block diagram shown in Figure 2 are shown in Figure 3 below.  Notice that the Mean Squared Error is 2.08188E-35.
Figure 3:  Overlap and Add Results
Zooming into the filtered graph shows clear details of the results of processing the entire data set or using overlap and add techniques.  Figure 4 below show the processing methods to be virtually identical.
Figure 4:  Zoomed Filtered Data Sets
Download the Overlap and Add LabVIEW Project
The Overlap and Add v2.zip project contains the cleaned up version of the diagrams demonstrating the benefits of using global variables to obtain a better signal flow representation of the filtering methods.
The original LabVIEW Overlap and Add project includes various implementations based on the same principle discussed in this tutorial.
  1. Download the Overlap and Add.zip or Overlap and Add v2.zip project
  2. Unzip the project file
  3. Choose an example from the project
  4. Configure the front panel controls for that example
  5. Run the VI using the Run arrow on the LabVIEW toolbar
Requirements to Run
Software
LabVIEW 8.6 Full Development System or newer
Hardware
N/A
Lalo Perez, Ph.D.
Academic Marketing
Singal Processing | Communications | Image Processing
Contributors
