Overview
This example will show the user how to use their DAQ card to output digital pulses based on an array of booleans. Make sure your DAQ card has a counter.
Description:
Using the counter of the DAQ hardware, we could basically generate a signal with a pattern by leveraging the characteristic of an array. In this example, the array would be filled by booleans value and thus the generation of the signal would follow the pattern of it
Steps to Implement or Execute Code:
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 9.0 or compatible
Hardware
cDAQ with C series Counter Output Module
