Example Code
Open file using System Executive in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example VI shows how to open up a file once a path is specified.
Description
Useful bit of code that allows you to open any file using the system executive tool. Simply run the VI, locate your file and click the button.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the VI
  2. State the file path and click 'Open this File' button.
VI Snippet
John McLaughlin
Academic Account Manager
National Instruments UK & Ireland
Comments
JohnMc19
Active Participant
Active Participant
on
Alternate method found here: http://decibel.ni.com/content/docs/DOC-14604
John McLaughlin
