Overview
This project is titled as Omni directional robotic arm & Live Surveillance for the purpose of pick and place and monitoring of the behavior, activities, or other changing information. which is to be constructed on hardware and software. This proposed project is to build a robotic arm that is capable to pick an object through the sensor attached to it and place the object accordingly to the coordinated places and also The wireless camera installed in the robot acquires the video which is transmitted to the user end and interfaced to the LabVIEW. The captured videos are processed for edge detection and saved using LabVIEW. The Ultrasonic sensor are used to detect the Obstacle distances.The system that will be build will be divided into four parts : Arduino mega circuit, driver circuit,wireless camera and ultrasonic sensor. These systems will be powered by 12v battery. To create a systematic, faster and efficient operation microcontroller ATmega2560 will be used. This microcontroller will function to process the input received from the keyboard through the usb cable and perform the corresponding action.
Description
Connect the DC motors to driver circuit,and input pins to Arduino pwm digital pin as in labview block diagram given below
and i use ultrasonic trigger input in arduino digital pin 36,echo pin 37.
select default name and path to save vid and click ok
Keyboard controls:
click record video and stop to save video.the video saved in avi format that u have choose the default path when program run
Requirements
Software:
Hardware
Additional Images or Video
Front Panel:
