Example Code
Ocean FX spectrometer Driver (Rebranded Ocean Optics as Ocean Insight)
Products and Environment
    Driver
  • LabVIEW Instrument Design Libraries for High-Speed Serial Instruments
    Other
  • ocean FX
Code and Documents
Description
I had problem obtaining high speed data from Ocean FX spectrometer using omnidriver. I decided to implement the known OBP protocol for controlling and reading data from the Ocean FX spectrometer directly via the USB port.
How to Use
I had written a small driver to replace the WinUSB driver with mine to read and write the USB port Labview Visa. Step 1. Replace the WinUSB driver with the OceanFX driver. Step 2 run the simple spectrometer VI to see if there is communication. The save high speed data into binary allows triggered high-speed acquisition from Ocean FX spectrometer. The analysis file provided will convert and graph the saved binary data. Enjoy!
Comments
mario_Cevese
Member
Member
on
Dear Chiki77
thanks for your contribution. I have an OceanFX, and I have tested your programs.
Is there any further evolution? I am comparing what you made with the Ocean Flame library available at http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=7833BD4A31DA1274E04400144FB7D2...
It would be great if you have done (or if you can make) something like that (with single blocks to make all operations)
Mario
Duckelly
Member
Member
on
Where did you find the bytes for the commands?
Duckelly
Member
Member
on
Where is the WinUSB driver that you replaced?
