Example Code
OPC Client - Read/Write Numeric Item Exmple
Code and Documents
Overview
This example VI shows how to use event structural to trigger code to write to an OPC Item while still being able to read from it.
Description
This example VI shows how you can use events to trigger your code to write to an OPC Item while still being able to read from it. The VI has been using with the 'National Instruments.OPCDemo>> NI OPC Demo Server>>Analog Items>>Integers>>VT_I2:1.0..1000.0' item. The program will read from the value every 100ms (the event structure timeout case) but will write the value in the Numeric control when you press the 'Set Numeric Item' button
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attached folder to your computer
  2. Open the VI "OPC Client 2012 NIVerified.vi"
  3. Run the program
  4. Select an OPC item from the pop tree menu
  5. Press the "Set Numeric Item Button" to write the value in the "Set Value Controller"
VI Snippet
James W
Controls Systems Engineer
STFC
Comments
CatLabMan
Member
Member
on
Where's that Browse OPC sub VI ?
JTG_Wilson
Member
Member
on
Hi MartinP,
I wondered who'd be the first to spot that obviously deliberate mistake (I didn't just forget to include it in the attached example, honest) and it's been 4 years before someone asked. I have no idea what was in the Browse OPC sub VI at this point but the program works fine by just using the 'DataSocket select URL.vi.
I've updated the attached VI and VI snippet so I hope this helps and thanks for letting me know about my mistake.
James
James W
STFC
