Overview
This VI predicts a string from multiple string inputs in which some characters are misspelled or not recognized by an OCR.
Description
You can add/ remove strings for more inputs depending on the number of strings you want to input.
This can be used for accurately predicting strings/numbers in an automation process which is very critical and you want implement redundancy in such systems by taking more measurements/ readings.
Requirements
- LabVIEW 2012 (or compatible)
- Open the VI " New Sound 2012 NIVerified.vi".
- Input 3 strings and choose the accuracy level.
- Run the VI.
VI Snippet
