Overview
Coding that exemplifies how to run a specific code for each possible range of an input value.
Description
Often times you need to perform different actions based on the value of a number. This is easy enough if discrete values correspond to cases. However floating point ranges can be slightly more difficult. This example code implements a solution to this problem.
Requirements
LabVIEW Base Development System (or compatible)
1. Edit the ranges to the ones you would like.
2. Run the VI
