Here is the small contributuion to the LVLIB for handling (parsing) NMEA GPS information made by MarcusTörndahl
Don't hesitate to add comment to get modification access for posting new versions!
Julien
Any chance some one could convert this to a zip file?
http://www.7-zip.org/ 7zip is free to download
Unfotunately 7 zip cannot be installed on this machine. Limited access rights etc. A zip file of the contents would be appreciated. Thanks for getting back to me.
I would appreciate it if somebody can convert and upload the library in LV2012 format.
Thanks.
Hi Mr_J
Thanks for this library. I'm trying to use it to get speed information from a NaviLock GNSS receiver. The receiver generates "$GN..." messages and not "$GP..." messages, so I had to include that option in the 'IF' block in the example VI and it seems to work - it at least is able to populate the GPRMC, GPGGA and GPVTG clusters correctly. However, it seems like the speed readings don't correspond to actual speed and the readings only update roughly every 8 seconds. Any idea why? With U-blox's u-center NMEA parser I am able to get live speed updates roughly every second. Is there something I'm missing?
Thanks.
Nevermind, its working correctly now. I just had to reduce the millisecond timer in the serial communication loop to 10 milliseconds.
