Example Code
Neural Nets written in LabVIEW !
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example provides a functional and clean Neural Net program for all to use as long as the author gets credit. Enjoy.
Description
This VI simulates a basic learning process through a Backpropagation Artificial Neural Network Model. This is a supervised model in which there are two input values sent to an input layer, the weight matrix passes to a hidden layer through a second weight matrix to the output layer. The chart shows the error vs repetitions of the input.
  1. Download the NeuraNet Example Zip file
  2. Unzip the file in a desired location
  3. Run the NN Example.vi for a quick working example to show the outcome
  4. More information is included in the Zip file within the project and also the txt file
  5. For more information about the topic, go to the link within the comments section of this page
Requirements to Run
Software
 LabVIEW Base Development System 2012 or compatible
Additional Images
Front Panel
Block Diagram
-Chuck Streb
chuck.streb@gmail.com
**This document has been updated to meet the current required format for the NI Code Exchange. **
Comments
BetaCommunityCo
Member
Member
on
Is there an explanation or documentation?
This appears to be an interesting example, however I am having a great deal of trouble following it as there's no documentation or comments. In looking at the code, I'd guess that everything makes perfect sense to those intimately familiar with neural nets (I read up on them some years back so I am certainly not intimate). Would it be possible to add documentation or point people to a resource?
carlfield
Member
Member
on
very goog code of ANN written by LabVIEW,although just BP ANN.
thank U very much!
ChuckS
Member
Member
on
here is some info
http://fbim.fh-regensburg.de/~saj39122/jfroehl/diplom/e-13-text.html
Yodo2
Member
Member
on
jincena
Member
Member
on
we have already done learning for bpn but do u have any idea on how to use this net for prediction
ChuckS
Member
Member
on
You need to unitize/scale (0to1) your inputs into this net and then convert back after.
Sorry I didn’t make a better example
PrimaryKey
NI Employee (retired)
on
Hi All, there is a very easy to use version of neural nets toolkit available for testing if you need.
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
ChuckS
Member
Member
on
current link for information
https://www.nnwj.de/backpropagation.html
