Example Code
.Net Message Error Box
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Use of the .Net Framework to call a user message box.
Description
Windows users with the .net framework installed can use this as an alternative to the LV Dialog Boxes.
Requirements
LabVIEW 2012 (or compatible)
1. Ensure the .Net reference is pointing the System.Windows.Forms.MessageBox class.
2. Insert the Text and Caption you would like to display.
3. Run the VI.
Thank You
Eric Reid
Motion R&D
Comments
Todd S.
NI Employee (retired)
on
Good stuff, thanks for posting.  Do you mind renaming your attachment to include the LabVIEW version?  "_lvXX.vi" would be good enough.  Thanks!
Todd S.
LabVIEW Community Manager
battler.
Active Participant
Active Participant
on
Isn't .NET framework even required to run the LV RTE regardless?  So if LV can run then this .NET call should run??
