Overview
The example demonstrates how to automatically segment a file created using the Embedded Data Logger custom device,
you can use a model created in LabVIEW.
Description:
Steps to implement or execute code
To implement this example:
Note: This model assumes that the Log Trigger channel is always true (= 1). Modifications will need to be made if the Log Trigger channel varies during deployment.
To execute this example:
Installation
Requirements
Software
LabVIEW 2012 or compatible
NI VeriStand
Hardware
Have you seen issues with the signals names not getting recorded? Data is there but signal names come out as Untitled 1, Untitled 2 and so on.
