若要下載 NI 軟體,包括下方所列的產品,請造訪 ni.com/downloads。
Overview
This example shows how to use the the VeriStand RealTimeSequenceDefinition API to create a Real-Time sequence and how to add that sequence to a Stimulus Profile. This allows you to programmatically edit and build sequences and profiles from a LabVIEW VI.
Description
The VeriStand .NET API allows you to programmatically control many of VeriStand's software operations from the LabVIEW environment. The Stimulus Profile Editor allows the user to create, modify, and execute test sequences. A stimulus profile can be used to call a real-time sequence to run on the real-time target. For more information on how to do this within the Stimulus Profile Editor, check out this document: Creating Real-Time Stimulus Profiles in NI VeriStand.
This VI shows how to create a real-time sequence and add it to your stimulus profile all within LabVIEW.The VI follows this sequence to do so:
1. Create a new real-time sequence.
2. Add x and y parameters of type double.
3. Set the return variable to also be a double.
4. Add the addition expression to the Main section.
5. Save the sequence.
7. Create a new Stimulus Profile
8. Load list of Steps in the Main section
9. Load Sequence as a Step
10. Configure the Call's Parameters
11. Add the steps back to the profile
12. Save the Stimulus Profile
Requirements
Software
Note: Could use later versions of the software but LabVIEW and VeriStand versions should match
Hardware
Steps to Execute Code
Description-Separate-2NI 社群中,來自 Example Code Exchange 的範例程式碼已含 MIT 授權。
