Example Code
NI SwitchBlock: NI-SWITCH Example for Multiple Device Explicit Path Connections
Products and Environment
    Hardware
  • Modular Instrumentation
    Software
  • LabVIEW
Code and Documents
Overview
This VI will make an explicit path connection from one column to another in an NI SwitchBlock device using NI-SWITCH.
Description
  1. Initializes your NI SwitchBlock device and sets its topology to the one you specify in Topology Name.
  2. Creates an array of row names and an array of analog bus names for your specific device.
  3. Allows the sharing of your analog bus over multiple devices.
  4. Makes multiple connections from one column to another as specified in the connection list on the front panel, and waits for the switch to finish closing.
  5. Terminates the NI-SWITCH session.
  6. Handles any errors that have occurred.
Requirements
Software
  LabVIEW version 2012 (or compatible)
  NI-Switch Driver version 4.6 (or compatible)
Hardware
  NI SwitchBlock and NI SwitchBlock Modules
  1. Select your NI SwitchBlock device name, and 'Configured Topology'
  2. Select the list of connections that you would want to make in the Connection List
  3. Repeat this for both your NI SwitchBlock devices
  4. Run the VI and the connections will be made as specified in your list of connections
Refer to the NI Switches Help for the valid channel names for your switch module.
I/O Connections Overview:
Refer to the NI Switches Getting Started Guide and NI Switches Help for information about connecting signals to your switch module.
Block Diagram
Frank,
Software Group Manager
