Overview
This VI will make an explicit path connection from one column to another in an NI SwitchBlock device using NI-DAQmx
Description
This VI accomplishes the following tasks during execution. The numbers in the sequence below correspond to the numbers on the block diagram.
1.Resets a switch device and sets its topology to the one you specify in Topology Name.
2.Makes multiple connections from one column to another as specified in the connection list on the front panel, and waits for the switch to finish closing.
3.Handles any errors that have occurred.
For I/O connection diagrams and information, refer to the NI Switches Getting Started Guide and NI Switches Help for information about connecting signals to your switch module..
Requirements
Software
Hardware
VI Snippet
