Example Code
NI-RFSA Soft Front Panel Measurement Examples
Products and Environment
    Hardware
  • PXI|VXI
  • RF|Wireless
    Software
  • LabVIEW
    Driver
  • NI RF Device Drivers
Code and Documents
Overview
Coding for some RFSA Soft Front Panel features that are not available in the Spectral Measurements Toolkit, or RFSA API for LabVIEW.
Description
When transitioning from using the NI-RFSA Soft Front Panel (SFP) to using LabVIEW, there are several measurement functions used in the SFP that are not available in the Spectral Measurements Toolkit (SMT) or NI-RFSA API for LabVIEW. Knowing this, National Instruments has created examples demonstrating how to perform measurements like CCDF, TOI, and SEM. Below there is a short description of each example provide in the library.
Within the analysis included we have the Complementary Cumulative Distribution Function, the Spectral Emission Mask, Third Order Intercept, Transmit Power, Trigger Spectrum, Video Bandwidth filter, and Zero Span. Included in each code is a simple description of what each analysis does.
Requirements
LabVIEW 2015 (or compatible)
1. Open the "NI-RFSA SFP Features exported to LabVIEW LV2015 - NIVerified.llb".
2. Select which analysis you would like to do.
3. Set the configuration information.
4. Run the VI.
Jim St
RF Product Support Engineer
Comments
tanim
NI Employee (retired)
on
Very useful to re-create SFP measurement results using LabVIEW code.
Tanim
Not applicable
on
thols
Active Participant
Active Participant
on
The interesting sub-VI's are password-protected, at least in VBW Example, so I cannot use this code since I cannot support it myself and NI does not support it. Or are these VI's available in the RFSA or RFmx installation somewhere? And the code does not show how to reproduce the SFP functions, which this page claims: https://www.ni.com/docs/en-US/bundle/ni-rfsa-sfp/page/rfsasfp/duplicating_results.html
Certified LabVIEW Architect
BranoBilanovic
Member
Member
on
Hello, What is the password for some of these block diagrams? Specifically I am trying to configure the FFT window type in the SEM configure or calculation VIs but can not configure because they are password protected. Thank you.
