This program was written to help users converting from the 6555/6 or other NI-HSDIO-supported instruments to instruments supported by the NI-Digital driver.
This code converts HWS, text, or binary files generated by the NI Digital Waveform Editor to .digipat and .digipatsrc files. The .digipat files can be directly opened with the NI Digital Pattern Editor for debug and/or modification. This converter also produces a .pinmap file and a .digitiming file, consisting of a single time set equal to your original waveform's sample rate with all pins defined as non-return.
As of this release, this converter does not support the following:
Could supply a LV2014 version code of this converter? Many thanks!
