From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
Example Code
NI-9411 Quadrature Encoder LabVIEW FPGA Example Code
Products and Environment
    Hardware
  • cRIO-9012
  • cRIO-9112
  • NI-9411
  • PXI-7811
    Software
  • LabVIEW
    Operating System
  • Windows
Code and Documents
Description
This example shows how to use multiple NI-9411 C Series Digital Modules in LabVIEW FPGA Interface programming mode. You will need to use LABVIEW FPGA Interface programming mode instead of Scan Interface proramming mode because the CompactRIO Chassis supports only two slots for specialty digital functions in Scan Interface programming mode. This example shows how to read quadrature encoder input signals on multiple modules.
How to Use
The attached example program demonstrates how to estimate velocity and acceleration of a Quadrature Encoder using the LabVIEW FPGA Module and CompactRIO hardware. This example consists of an FPGA VI, Encoder Position & Velocity (FPGA).vi, which will run on the FPGA platform and a host VI, Encoder Position & Velocity (Host).vi, which will run on the Host Machine. Additionally, the example program was designed for a PXI-7811R PXI Digital Reconfigurable I/O Module FPGA and an R Series expansion chassis with a NI-9411 DI module in slot 1.
Additional Information
The attached VI can easily be modified to run on any other CompactRIO FPGA hardware.
Related Links
Contributors
