Overview
This example demonstrates how to make programmatic visual changes to the .NET Month Calendar form.
Description
With Windows Vista and newer some .NET forms are rendered at run time using the current operating system theme. Depending on the theme, setting certain properties might not change the appearance. If you want to see these changes in your LabVIEW application, you should disable Windows Visual Style. This setting is then re-enabled at the end of the program to ensure that other applications display as expected. This example demonstrates just a few random property changes to show how this is accomplished.
Note: Disabling Visual Styles might affect the appearance and behavior of other controls in your application.
Requirements
VI Block Diagram
Thank you very much 🙂
