Overview:
Coding that exemplifies how to obtain data from the different Windows Interface Statistics.
Description:
This code consists on retrieving network statistics with LabVIEW. Under the hood it uses .NET to obtain the names of all installed interfaces. Also, we will obtain the amount of bytes sent and received.
Requirements:
1. LabVIEW 2012 or compatible
2. .NET Framework 2.0 or compatible
Steps to Implement or Execute Code:
1. Run the VI
Additional Information or References:
First Cutomer Contributor!
Thank you very much for contributing your example, Philip. This is a perfect example of the type of content we are looking for!
I wish I had money in my budget to send you a prize like the kid who won something for being the 1 millionth downloader on iTunes...
Older version?
Any chance at a 7.1 version?
Saved and tested in LV 7.1
I've saved and tested the VI using 7.1. If your installation of 7.1 is old, you may want to read about using 7.1 and .NET 2.0 at Brian Tyler's BLOG; see http://detritus.blogs.com/lycangeek/2005/06/labview_and_net.html You still need to install the .NET 2.0 framework.
