Example Code
.NET Example: Start and Stop Windows Services Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how .NET can be used to start and stop Windows Services programmatically without having to use System Exec commands.
Description
System Exec does not allow for the command prompt to be ran as an administrator. To get around this, an application and installer must be created or LabVIEW itself has to be ran as an administrator. This example provides a workaround to control Services using .NET. The benefit is that it can elevate the permissions for the application to gain access to certain Services without having to build an executable or having to run LabVIEW as an administrator as you would with System Exec. It uses runas and net commands to configure the process through .NET. The default configuration is set to turn on/off Windows Themes. This was inspired from lavag.org.
Note: Disabling some Services can cause unexpected system behavior. Research any Services prior to running this VI.
Requirements
  • LabVIEW 2012(or compatible)
  1. Open and configure the Front Panel controls
  2. Run the VI
David C
Comments
DexterL
Member
Member
on
This. Was. Perfect. Timing.
I see that this was posted on Jan. 3 and the last task I started on Jan. 3 was a System Exec call to stop a service. I started the struggle and search this morning and ran across this little snippet just before lunch. Thanks for saving me any further headache and head scratching!
--Dexter LaGrand.
SoftWEng
Member
Member
on
Thank you.  Also found this example very useful.  Is there a way to check if the service is running the same way in this code?
