Multiple Terminal Configurations in Same Task Using LabVIEW with DAQmx
Overview
This VI captures analog input data using different terminal configurations in the same task.
Description
Sometimes you will need to capture analog input data using different terminal configurations (RSE, NRSE, Differential) on the same device. You can do this by using several Create Channel VIs, setting their individual properties, and stringing them together in the same task.
Requirements
VI Snippet
