Example Code
Multiple Plots and Scales on One Graph Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows a quick way to be able to plot 2 signals on a graph and have their respective scales on different sides.
Description
This VI shows 2 signals on the same graph with their own respective scales. It looks like 1 graph but it is actually 1 graph on top of another. The Cos graph was created separately and the Tools Palette was used to make everything transparent other than the signal itself and the scale.
Requirements
  • LabVIEW 2012 (or compatible)
  • Select the device sine and cos amplitude.
  • Run the program
Front Panel
Kind Regards
Michael
NIUK Application Engineer
Comments
D*
Member
Member
on
An alternate way to do this natively in LabVIEW is to add another y-axis scale.  To do this:
1. Right click the existing y-axis scale and choose "Duplicate scale".
2. Typically, I like to have the scales on different sides of the graph as you have shown. So the next step is to right click one of the y scales and select "Swap sides".
3. Now you need to register each plot with the appropriate scale.  Right click the plot in the plot legend, and select "Y scale" at the bottom which will open a menu to the y-axes that you have created.
The nice part about doing this natively in the graph, is that both graphs will continue to share the same x-axis and all of the graph tools work as expected.
sanjeeev
Member
Member
on
well, it would be really nice if you could detail how you actually got those 2 plots ( cos and sine ) on the same graph. you have just mentioned you made one transparent using the tools palette . but how>?
Thank You
ragu_C
Member
Member
on
Do you have any idea about duplicate Y scale by programmatically?
Thank you
