Example Code
Multiple PWM Generator
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Description
This application demonstrates how to use DAQmx to create multiple PWM channels and have runtime-control over Frequency and/or Duty Cycle.
Steps to implement or execute code
To implement this example:
  1. Set the physical channel of the counter
  2. Determine the frequency
  3. Run the VI
  4. (Optional) Turn on the Highlight Execution to see the flow of the VI
To execute this example:
  1. Install the required software.
  2. Connect the DAQ hardware that supports the Counter features
  3. Confirm the connection with the MAX with TestPanel
  4. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Counter Input Module
2017-10-30_16-08-49.jpg2017-10-30_16-08-49.jpg2017-10-30_16-08-38.jpg2017-10-30_16-08-38.jpg
