Example Code
Multi-User Slot Machine Game using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example VI is a slot machine game built with LabVIEW.
Description
When Slot Main 2012 NIVerified.vi is started, the VI prompts the user for their name.  If the name is found, the VI will retrieve their number of credits; if no entry is found, it will give the user 500 credits to start.  Should a user run out of credits, the user can reset their number of credits to 250 by clicking the "Reset Credits" button and entering the passwork "admin".
Every time a bet is placed, the new number of credits is written to the "User Data.txt" file.  If the text file does not exist (i.e. the first time the VI is run) it will make one.
How to Win:      Match all three numbers and win up to 200 times what you bet
                         Match two numbers and win up to 15 times what you bet
If no items match you can still win back some of what you bet, or lose all of what you bet
Requirements
  • LabVIEW Base Development System 2012 (or compatible)
  1. Unzip the attached folder to your computer
  2. Open the LabVIEW Project "Slot Machine 2012 NIVerified.lvproj"
  3. Open the VI "Slot Main 2012 NIVerified.vi"
  4. Run the program
VI Front Panel
VI Block Diagram
Brandon L.
Automation Engineer
