Overview
This VI shows how to perform synchronized analog input on two devices using the producer/consumer architecture.
Description
This VI is meant for large sampling rate applications with several channels. Use this template to build a producer/consumer design pattern. Use this template when you need to execute a process, such as data analysis, when a data source, such as a triggered acquisition, produces data at an uneven rate and you need to execute the process when the data becomes available.
Requirements
VI Snippet
