Overview
This VI will read in an analog input channel and then write that signal out on an analog output channel on the same device.
Description:
The example would shows you how to generate a signal from the Analog Output pin of the DAQ hardware and sequently acquire the generated signal and shows what the signal is. It is a great simple way to verify both of the functions of the hardware.
Steps to implement or execute code
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Analog Input Output Module
When I run this vi using an external function generator, the ao and ai signal magnitudes (p-p) differ by several hundred millivolts. The difference appears to vary with ai magnitude and maybe even frequency. Any idea what gives? I'm using cdaq ai and ao modules.
