Overview
Program that shows how to move a control programmatically through the Front Panel using the Position property of VI Server.
Description
This code consists of moving a button control through a particular area by setting the proper coordinates selected by the user. If the user specifies a coordinate value outside of the allowed bounds, the button will be moved to the respective initial value (for the horizontal value is 252, and for the vertical value is 72). The maximum coordinate allowed is (528,352).
Requirements
LabVIEW 2012 (or compatible)
1. Open the "Move Control Programmatically LV2012 NI Verified.vi".
2. Select the Run button.
3. Use the Horizontal and Vertical controls to set the coordinates in which you would like to have the button on.
