Example Code
Morphed Sum of Images
Code and Documents
Functional Description
This example allows the user to get an image output that is the weighted sum of two chosen images. A slider control that goes from 0 to 1 determines the weightage of both images in the sum. For example, in the case of Images A and B, a slide value of 0 would result in a sum of 0% A + 100% B. When the slide value is 1, sum = 100% A + 0% B.
Caveats and Additional Notes
LabVIEW 8.2, Vision Development Module 8.6
Vivek Nath
Machine Vision
Comments
HunterSeeker
Member Member
Member
on
Thanks for posting, could you please add screenshots of your block diagram and front panel!
Hunter
Contributors
