Example Code
Monitoring of Keyboard Buttons that are Pressed
Code and Documents
Overview
This VI initializes a communication with the keyboard and then monitors what buttons are pressed on the keyboard.
Description
This example opens a reference with the keyboard and then monitor the keys pressed on the keyboard using the Acquire Input Data.vi available in the inputDevices.llb. Check Context Help for more information The indicator on the front panel then displays what buttons are being held down. it can detect when several buttons are being pressed at the same time.
Requirements
LabVIEW 2012 (or compatible)
1. Open and run the VI "Monitor Keyboard Presses_LV2012_NI Verified"
2.. Press any button on the keyboard
Chris Van Horn
Comments
Xent
Member
Member
on
Hello Chris, I'm very intrested in this file but I cant use it as I'm on LabView 7.1
is there someway you can help me with this,
I would like with a keyboard button press, to activate a Boolean button on the front panel, insted of hitting it with the mouse, please email me.
JerPee
Member
Member
on
Hello Chris,
I am now using this VI, but although I'm typing on an azerty keyboard, the VI thinks that I'm typing on a qwerty. Do you have any idea how this comes?
Kind regards,
Jeroen
