Example Code
Monitoring Mouse Movement and Moving the Front Panel
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to make the front panel moves while with the mouse while on a determined area.
Description
This is a VI might be used when wanting to move the front panel from a specific area, but does not want to have the menu bar. It takes the difference in current position vs last position and moves the front panel the same way. This shows how event structures can be useful in application control.
Requirements
LabVIEW 2012 (or compatible)
1. Run the VI
2. Place the mouse on the white square, click and move it.
3. Click on the stop button in order to finish the execution.
undefined
Chris Van Horn
