Example Code
Modify Prompt User Input Express VI To Have Default Values Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
The Prompt User for Input Express Vi is an easy VI to show a dialog box in which the user will enter values and click on an OK button to continue with the VI
Description
The user can select the data type to be used in this Express VI, but every iteration of the VI defaults to the default value of the data type (0 for numeric, empty string for text box, etc.). The attached VI shows how to set custom default values for this VI, as well as retaining the values entered, if desired.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Put down a Prompt User for Input Express VI on the block diagram of a VI
  2. Configure the Express VI for the Message, Inputs, Buttons, and Window Title that you want. Click OK when finished.
  3. Open the front panel of the VI by right-clicking on the Express VI and select Open Front Panel.
  4. Move the inputs from inside the While Loop to the right outside the loop.
  5. Rewire inputs to their respective outputs, then create shift registers.
  6. On the Front Panel, enter the values in the controls that are to be the default values. Then select Edit » Make Current Values Default.
  7. If you want the VI to retain the values entered on previous iteration, instead of reinitializing every time, remove the Default Values,and Reinitialize all Invoke Node
Robert R. | Applications Engineer | National Instruments
